new purchase, monitor issues.
16 Feb 2010
hi ive recently bought this system
"Titan Krypt" AMD Athlon II X4 630 2.80GHz Quad Core DDR2 System
screen shows up fine with the adapter from dvi to vga then into my monitor.
now i want to connect my second screen, a 32" lcd tv via hdmi.
if i start the pc with both plugged in i get as far as the windows is loading sceen, then my monitor and tv goes blank. there is a signal there but its not showing on the screens. also if i start with just the hdmi cable in i get the same.
is there some settings i need to change first before i can use hdmi.
help would be most appreciated.
james
