Just got an EK XE 480, says on the box that it doesn't need to be cleaned before installation but I washed it anyway and there was quite a few black spots came out into the bath
When I took it out of the box I noticed it had a noticable chemical odour ( couldn't say exactly what ), thought it might have just been the packaging
but I think its the paint they have used on the fins or enclosure,
drying it with a hot air fan and its worse now ( fills the entire garage )
Does anybody else have this radiator ? do you think it will fade quickly ? should I wash it with certain ingredients e.g. soap ?
Had about 4 other radiators prior to this and not experienced similar before with the others ( AX 360 etc )
