Updated the title, I do need help with this if anyone can advise please..
so I’ve just finishing putting my computer together after repairing my 2600 and knew it probably wouldn’t be straight forward, but I’ve got a weird memory thing and never having this much memory before I don’t have a clue what’s going on nor have time to look at it now, but need advice all the same.
So changes To the computer in sig Now look like this.
2600
Aorus M
20gb ballistix sports 3 x single channel 4gb & 1 x single channel 8gb
Gtx 1060 6gb
Silverstone 450w sfx
So according to CPUZ I’m running in dual and while I did xmp to 3000 they are reading at standard 2400 still? I know I had 2933 when I had 12gb, but I thought I’d test a little higher, but then even 2933 wasn’t setting, but the computer is running all the same.
Now in task manager despite detecting 20gb, it’s saying these figures which I don’t quite understand
In use - 3.5gb(57.2mb compresses)
4.3gb available
5.2/9.8gb committed
4.4gb cached
Speed 2400mhz
4 of 4
12.1gb hardware reserved
Now my m.2 drive(boot drive) and couple others haven’t been detected likely due to the ports I’ve used, so I’m using a slightly older drive I had windows 10 on, so not exactly up to date, but task manager says I’m using 3.4gb out of 7.9, which isn’t obviously not correct either.
The bios is F5, I haven’t got the time to update it before Monday, but would that be the likely cause? I know I’m using single channel ram but hadn’t had issues when I had 12gb, however I’m not sure how the ram goes in, so I figured 4448 setup thinking it wouldn’t matter which slot they were in?.
I don’t have a real issue then running at 2400, but would like them to run at least 2933 if nothing else.
2600
Aorus M
Gtx 1060 6gb
4.3gb available
5.2/9.8gb committed
4.4gb cached
Speed 2400mhz
4 of 4
