New Ram Problem
17 Mar 2009
Hi there, hopefully someone maybe can help, July 2010 I bought a overclocked bundle from Overclockers which comprised of a i5 760 2.8ghx overclocked to 4.0ghz, asus P7P55D-E mobo and 4gb of xms 3 ram, ive just added another 4gb's of the same ram and once restarted the processor reverted back to 2.8ghz. Ive tried to go back into the bios and reload the overclocked preset that Overclockers saved on there but it wont let me get into the bios at all (ive only tried getting into the bios by pressing delete while the system starts up) any help would be appreciated.
It's defiantly <DEL> to enter BIOS for that motherboard. Make sure you do this during the initial POST. Did you hit F1 to reset or anything like that after installing the new RAM?
What kind of keyboard are you using? Try connecting a PS/2 type keyboard or converter as I've experianced this at time.. As for the settings, I think you'd be best off contacting the shop directly.
