** New range of AeroCool fan controllers at OcUK ** - Pre-Order Now!
20 Jul 2009
The bleak North East arm pit of Britain
Hello
We have a range of AeroCool fan controllers coming in to stock hopefully early next week so if your looking for a fan controller the range just got bigger! :D
AeroCool F4XT 4-Channel Fan Controller with USB ports @ £13.99 inc VAT
Controlling the fans on the F4XT is done individually via the touch buttons on the front of the controller. The attached fans can be controlled in three steps: low / medium / high with the LEDs indicating which step is selected for each fan. The LEDs can be turned off. Also on the front of the panel are two USB ports for your convenience.
- Controls up to four 4-pin molex fans
- Three adjustable speeds: Low / Medium / High
- LED off function
- Supports up to 12W per channel
- Two USB ports
- Dimension: 148.6(W) x 42.5(H) x 65(D)
- Fan connectors: Molex 4 pins
- Max. wattage per fan channel: 12W
Only £13.99 inc VAT.
ORDER NOW
AeroCool F6XT 6-Channel Fan Controller @ £14.99 inc VAT
Controlling the fans on the F6XT is done individually via the touch buttons on the front of the controller. The attached fans can be controlled in three steps: low / medium / high with the LEDs indicating which step is selected for each fan. The LEDs can be turned off, alternatively they can be Red instead of Blue!
- Controls up to six 4-pin molex fans
- Dual LED colours + LED off function
Only £14.99 inc VAT.
ORDER NOW
AeroCool X-Vision 5-Channel LCD Fan Controller @ £31.99 inc VAT
The AeroCool X-Vision 5-Channel LCD Fan Controller controls up to five fans and displays temperature readings making this unit great for controlling your cooling needs.
- Controls and monitors five fans with temperatures
- Overheating alarm temperature warning
- LCD back light on/off option
- Fan RPM display
- Fan voltage display
- Dimension: 149 (W ) x 42.5mm (H )
- LCD viewable area: 104mm (W ) x 21mm (H )
- Connectors: 5 x 3-pin fan connector / 5 x heat sensors
- Material: ABS front bezel with steel bracket
- Max wattage per fan channel: 8W
Only £31.99 inc VAT.
ORDER NOW
AeroCool V12XT 4-Channel LCD Touch Panel Fan Controller @ £38.99 inc VAT
AeroCool are well know for producing some of the best fan controllers around and the V12XT helps to confirm this. Similar to the Touch 2000, the V12XT offers the ability to control up to four fans via a well thought out LCD touch panel display which shows the RPM of each installed fan. It also shows temperature readings of the four supplied temperature probes. These probes are to be placed next to or on critical components like the CPU and GPU heatsinks as well as items like hard drives and any other component that requires to be monitored. There is also the option of showing HDD activity on the panel.
- Large LCD screen
- HDD activity display
- Lock function provided to prevent careless miss-touch
- Dimension: 149.5 (W) x85 (H) x 70(D) mm
- LCD viewable area: 115 (W) x 57 (H) mm
- Connectors: 4 x 3-pin connectors / 4 x heat sensors
- Material: ABS front bezel w/ steel bracket
- Max wattage per fan channel: 6W
Only £38.99 inc VAT.
ORDER NOW
AeroCool Touch 1000 4-Channel LCD Touch Panel Fan Controller @ £28.99 inc VAT
AeroCool are well know for producing some of the best fan controllers around and the Touch 1000 helps to confirm this. Like its big brother, the Touch 2000, it offers the ability to control up to four fans via a well thought out LCD touch panel display which shows the RPM and temperature for the selected fan/probe. But unlike the Touch 2000 that requires two 5.25" drive bays the Touch 1000 has all this functionality crammed into just one 5.25" drive bay.
- Stylish hair brushed aluminium front panel with diamond cutting
- Innovative Touch LCD technology
- Monitors and controls four fans and displays temperatures
- Dimension: 149.5 (W) x 42.5 (H) x 70(D) mm
- LCD viewable area: 118 (W) x 25 (H) mm
- Material: Brushed aluminium front bezel w/ steel bracket
Only £28.99 inc VAT.
ORDER NOW
AeroCool Touch 2000 4-Channel LCD Touch Panel Fan Controller @ £41.99 inc VAT
AeroCool are well known for producing some of the best fan controllers around and the Touch 2000 helps to confirm this. It offers the ability to control up to four fans via a well thought out LCD touch panel display which shows the RPM of each installed fan. It also shows temperature readings of the four supplied temperature probes. These probes are to be placed next to or on critical components like the CPU and GPU heatsinks as well as items like hard drives and any other component that requires to be monitored. And if that was not enough the Touch 2000 also adds two USB ports, an eSATA port and audio ports for your convenience.
- Innovative Touch sensitive LCD panel
- Monitors and controls four sets of temperature and fan speed
- LCD backlight on/off
- 1 x e-SATA , 2 x USB , mic and headphone
Only £41.99 inc VAT.
ORDER NOW
With that fancy pants last one, are the audio connectors extensions to the MB or audio card or is there a USB sound controller on-board so these are a separate Windows sound device?
Guessing its just extensions to the MB or Audio card, same for the usb and esata
