*** *** ViewSonic VA1913w 19" Widescreen LCD Monitor @ £89.99 inc VAT *** ***
ViewSonic’s 19" VA1913wm 16:9 widescreen display features aspect ratio selection in the OSD to ensure a full, undistorted screen image. High brightness and fast video response deliver brilliant, blur-free images, while the ultra-high 10,000:1 dynamic contrast ratio produces greater detail and definition especially in darker images. Ecomode automatically conserves power when not in use. The VA1913w is suited to home/small office users, students, gamers and corporate professionals.
- Screen Size: 19" Widescreen
- Resolution: 1366x768
- Contrast Ratio: 10000:1
- Brightness: 300cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue
- VESA Compliant
- Dimensions: 447.0mm x 350.0mm x 199.0mm
- Weight: 3.4kg
- Warranty: 3 Years On-Site
Only £89.99 inc VAT.
ORDER NOW
*** *** ViewSonic VA2013wm 20" Widescreen LCD Monitor @ £96.98 inc VAT *** ***
ViewSonic’s 20" VA2013wm LCD brings value to big, widescreen displays. This display doesn’t compromise on features with 1600x900 resolution for brilliant HD images. This stylish 20" LCD delivers extreme clarity, amazing color with 20000:1 dynamic contrast ratio and fast ClearMotiv 5ms video response. Benefit from greater productivity with the ability to view two fullsize documents side-by-side or work in multiple applications simultaneously on the widescreen display. Integrated speakers in a stylish, slim-bezel design provide multimedia enjoyment. Eco-mode conserves power and can extend backlight life. VA2013m fits seamlessly into any office décor. It’s great for desktop applications at home, school or in the office.
- Screen Size: 20" Widescreen
- Resolution: 1600x900
- Contrast Ratio: 20000:1
- VESA Compliant
- Dimensions: 481.0mm x 369.0mm x 200.0mm
- Weight: 4.12kg
Only £96.98 inc VAT.
ORDER NOW
*** *** ViewSonic VA2213w 22" Widescreen LCD Monitor @ £111.99 inc VAT *** ***
ViewSonic’s 22" VA2213w 16:9 widescreen features aspect ratio adjustment that ensures a full, undistorted screen image. High brightness and fast video response deliver brilliant, blur-free images, while the ultra-high 16000:1 dynamic contrast ratio produces greater detail and definition especially in darker images. Eco-mode saves up to 40% in energy use and prolongs lamp life. The VA2213w is the right choice for home/small office users, students, gamers and corporate professionals.
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 16000:1
- VESA Compliant
- Dimensions: 512.0mm x 388.0mm x 246.0mm
- Weight: 4.8kg
Only £111.99 inc VAT.
ORDER NOW
- VESA Compliant
- Weight: 3.4kg
ORDER NOW
- VESA Compliant
- Weight: 4.12kg
ORDER NOW
- VESA Compliant
- Weight: 4.8kg
ORDER NOW
