- 28 Sep 2017
Unleash your inner weeb and deck out your desk with our new Razer Quartz peripherals!
Available in pink, pink and uh.. pink!
Razer Kraken - Multi-Platform Wired Gaming Headset - Quartz Edition
(PC/PS4/SWITCH/XBOX/MAC) @ £99.95 inc VAT https://www.overclockers.co.uk/raze...edition-pc-ps4-switch-xbox-mac-sp-04y-ra.html
Custom-tuned 50 mm Drivers, Cooling Gel-Infused Cushions, Retractable Unidirectional Microphone, Bauxite Aluminum Frame, Thicker Headband Padding, Cross-Platform Compatibility
Only £99.95 inc VAT.
ORDER NOW
Razer Huntsman Opto-Mechanical USB RGB Mechanical Gaming Keyboard - Quartz @ £149.99 inc VAT https://www.overclockers.co.uk/raze...hanical-gaming-keyboard-quartz-kb-12v-ra.html
New Razer Opto-Mechanical Switch™ – Light and Clicky, Key stabilizer bar for precise, balanced actuation, Hybrid on-board memory and cloud storage, Up to 100 million keystrokes
Only £149.99 inc VAT.
ORDER NOW
Razer Basilisk - Multi-color FPS RGB Optical USB Gaming Mouse - Quartz Edition @ £64.99 inc VAT https://www.overclockers.co.uk/raze...sb-gaming-mouse-quartz-edition-kb-12u-ra.html
The world's most advanced optical gaming sensor, Scroll wheel with customizable resistance, Removable DPI clutch in 2 different lengths, Gaming-optimized Razer™ Mechanical Mouse Switches
Only £64.99 inc VAT.
ORDER NOW
Razer Goliathus Extended Chroma - Soft Gaming Mouse Mat with Chroma RGB - Quartz @ £59.99 inc VAT https://www.overclockers.co.uk/raze...use-mat-with-chroma-rgb-quartz-gs-04d-ra.html
Balanced for speed and control playstyles, Optimized surface for all mice and sensors, Inter-device color synchronization, 294x920x3mm
Only £59.99 inc VAT.
ORDER NOW
Razer Base Station Chroma - Chroma Enabled Headset Stand with USB Hub - Quartz Edition @ £59.99 inc VAT https://www.overclockers.co.uk/raze...nd-with-usb-hub-quartz-edition-sp-04x-ra.html
Detachable headphone stand, 3-port USB 3.0 Hub, Razer Chroma enabled, Full programmable with Razer Synapse, Anti-slip feet
ORDER NOW
Razer Raiju Tournament Edition - Quartz Edition Wireless and Wired Gaming Controller PC/PS4 @ £149.99 inc VAT https://www.overclockers.co.uk/raze...wired-gaming-controller-pc-ps4-gc-00c-ra.html
Works with PS4 and PC, Bluetooth/Wired connection, Mobile app for easy configuration, Ergonomic multi-function button layout
ORDER NOW
Razer Seiren X Quartz Edition Condenser Streaming Microphone @ £99.95 inc VAT https://www.overclockers.co.uk/raze...condenser-streaming-microphone-sp-04z-ra.html
Condenser microphone made for streaming Supercardioid pick-up pattern to reduce background noise, Built-in shock mount to dampen vibrations, Mute button, Zero-latency 3.5 mm headphone monitoring port
ORDER NOW
