- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Razer have announced their new peripherals. OcUK as ever are first to market on these products
Get your pre orders in early!
Razer Orbweaver Elite Mechanical Gaming Keypad @ £114.98 inc VAT
The Razer Orbweaver’s mechanical key technology provides a distinctive tactile feedback in the form of a light pronounced tap and click to your fingertips, giving you an entirely new feel as you game. Each key has an optimized actuation force of 50g and a reduced actuation distance of 2mm, letting you unleash commands and attacks at a blisteringly fast rate. Watch as your actions-per-minute soar to devastating heights, leaving adversaries eating your dust.
Arm yourself with 20 fully programmable mechanical keys for more skills, hotkeys, and macros right at your fingertips. A programmable 8-way directional thumb-pad can also be used either for movement or as modifier keys to expand your repertoire of game-destroying abilities.
The Razer Orbweaver was designed with adjustable, hand, thumb and palm-rest modules to let you customize the most comfortable experience with the keypad during marathon gaming sessions. Slide either part back or forth so that it sits under your thumb or cradles your palm perfectly, reducing hand fatigue, and optimizing ergonomic access to your controls.
Synapse 2.0 is our unified configuration software that allows you to rebind your buttons, assign them macros and saves all your settings automatically to the cloud. It ports your settings immediately from the cloud no matter where you are. It also supports our other Razer peripherals to provide a seamless experience.
- Full mechanical keys with 50g actuation force
- 20 fully programmable keys
- Programmable 8-way directional thumb-pad
- Adjustable hand , thumb, and palm-rests modules for maximum comfort
- Instantaneous switching between 8 key maps
- Unlimited macro lengths
- Stores unlimited game profiles
- Backlit keypad for total control even in dark conditions
- Synapse 2.0 enabled
- Approximate size: 55 mm / 2.17” (Depth) x 154 mm / 6.06” (Width) x 202 mm / 7.95” (Height)
- Approximate Weight: 300 g / 0.66 lbs
Only £114.98 inc VAT.
ORDER NOW
Razer Sabertooth Elite Gaming Controller for Xbox 360 & PC @ £69.98 inc VAT
The Razer Sabertooth Elite Gaming Controller for Xbox 360 & PC is the supercharged successor to the award-winning Razer Onza. Now, it has been restructured with even more customizability and control options in an all new, rugged design that doesn’t compromise comfort.
An unprecedented six additional multi-function buttons – two at the shoulders and two removable rocking switches at the bottom of the controller – allow you to react to any situation or enemy instantaneously by putting more power right at your fingertips. The Razer Sabertooth lets you reconfigure your choice of buttons elsewhere on the controller to any of the six multi-function buttons.
With an integrated OLED screen on the Razer Sabertooth, you get ease of customizability over the controller’s multitude of features. From programming the multi-function buttons, to adjusting the analog stick’s sensitivity, and creating profiles, you’ll be setting the controller up just the way you want it.
The best professional gamers are masters of their equipment, not the other way round. The Razer Sabertooth was made to make sure you’re perfectly set up for winning.
- 2 shoulder multi-function buttons (MFB)
- 4 removable multi-function buttons (MFT)
- 4 backlit Hyperesponse action buttons
- OLED screen for feature customization
- Non-slip rubber surface
- Quick-release USB connector
- Detachable 10 ft/3m lightweight braided fiber cable
- Carrying case
- 2.5mm microphone jack
- Approximate size : 110mm / 4.33” (Length) x 154mm / 6.06” (Width) x 57mm / 2.24” (Height)
- Approximate weight: 288g / 0.63 lbs
Only £69.98 inc VAT.
ORDER NOW
Razer DeathStalker Expert Keyboard @ £69.98 inc VAT
The slim 2mm chiclet keycaps on the Razer DeathStalker ensure less time is needed to actuate each key so you can react faster to situations and enemies. Your fingers can move quickly between the keys, ensuring your entire master plan for gaming domination is executed instantly.
Actuate as many keys as you have fingers, and have all of them register accurately and quickly in-game. With the Razer DeathStalker’s anti-ghosting capabilities, you can deliver overwhelming destruction to your opponents, and ensure that every command is registered and executed perfectly.
Razer Synapse 2.0 is cutting-edge, intuitive software that functions as the Razer DeathStalker’s brain, automatically syncing the gaming keyboard to a cloud server to download driver and firmware updates, while saving your individual settings. Sync your custom settings and macros automatically with this unified configurator, allowing customization of all your Razer products with a single login.
- Chiclet style key caps
- Green LED Backlit keys
- 1000Hz Ultrapolling
- Fully programmable keys with on the fly macro recording
- Razer Synapse 2.0 enabled
- Dedicated Gaming mode
- Anti-ghosting capability for up to 10 simultaneous key presses
- Fixed wrist rest
ORDER NOW
ORDER NOW
- Carrying case
ORDER NOW
- Fixed wrist rest
ORDER NOW
