- 14 Jan 2011
- Aylesbury
Hi,
Im putting several build options together ready for a new build around BLK Friday.
I am looking at Amd, Intel Nvidia etc and have not decided yet which options to go with, but I would like your advice on this basket with regards to building it with the components supplied.
I like the look of the RGB effects you can get these days and am considering a vertical mount GPU to show of the card
My Preference at the moment is th Lian Li O11 Dynamic but have also included a few other case I would consider.
I want to mount the 360 CPU cooler on the side of the Lian Li Dynamic case if at all possible.
I am unsure if this large GPU will be too close to the glass panel or hit the cooling unit in its desired position using the Lian Li bracket or an aftermarket bracket.
Would an after market bracket be better and sit the card in the centre more?
Could you please give me some advice if this will work with this case, if it will all fit in, I am open to any other input , recommendations or feedback which would be greatly appreciated.
Thank you
My basket at Overclockers UK:
Thank you
- 1 x Lian-Li O11D-1 PCI-Express Riser Cable - Black= £54.95
- 1 x Lian-Li PC-O11 Dynamic Midi-Tower - White Window= £119.99
- 1 x ThermalTake Floe Riing RGB TT Premium Edition Water Cooling Unit - 360mm= £179.99
- 1 x Aorus GeForce RTX 2070 SUPER 8192MB GDDR6 PCI-Express Graphics Card= £578.99
- 1 x Lian Li O11 Dynamic XL (ROG Certified) Aluminium Midi-Tower - White= £199.99
- 1 x NZXT H700i Midi Tower Gaming Case - White= £179.99
- 1 x NZXT H510i Midi Tower RGB Gaming Case - White Tempered Glass= £109.99
