New Rig Need Advice
20 Feb 2010
New Rig £1800 Need Advice
APPROXIMATE PURCHASE DATE: BUDGET RANGE: £1700/£1800
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming,More Gaming,Movies
PARTS NOT REQUIRED: keyboard, mouse, monitor
PARTS PREFERENCES: Cpu Intel i7 920, Graphics XFX ATI Radeon HD 5870,full Tower gaming case
OVERCLOCKING: Yes SLI OR CROSSFIRE: Yes (in the next 6 months)
MONITOR RESOLUTION: current monitor is 1680x1050 (but in the next month i will be buying 3 x (1920x1200) new monitors (so if you have any suggestions on good Triple display monitors please comment
ADDITIONAL COMMENTS:
i have a few questions,worries
1.the Asus Rampage II Extreme motherboard is BIG and im worried that it might cause problem fitting and keeping good airflow also is this motherboard that good for pro/price or should i go for Gigabyte GA-EX58-Extreme Intel X58
2. Cpu cooler should i get Prolimatech Megahalems Or H50-1 or another type
3 will i need any extra fans like Noctua NF-P14 FLX (for when i get my second 5870)
3. also any other feed back and suggestions would be great
below is an example of the setup im going to be using
Combo Deal
http://www.overclockers.co.uk/showproduct.php?prodid=BU-045-OE
Gpu
http://www.overclockers.co.uk/showproduct.php?prodid=GX-147-XF
Power supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-012-CS
SDD
http://www.overclockers.co.uk/showproduct.php?prodid=HD-007-KS
Case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-102-AN
OS
http://www.overclockers.co.uk/showproduct.php?prodid=SW-124-MS
HD
http://www.overclockers.co.uk/showproduct.php?prodid=HD-080-SA
Memory airflow
http://www.overclockers.co.uk/showproduct.php?prodid=HS-000-CS
Drivers
http://www.overclockers.co.uk/showproduct.php?prodid=CD-039-OT
thanks for reading :)
Hi there,
The PSU is a bit excessive, you won't need more than 750W to power any of today's computers, have a look at this article:
http://www.xbitlabs.com/articles/coolers/display/system-wattage.html
Also, if you're at school/uni you can get Windows much, much cheaper through Microsoft's own student program.
EDIT-P.S.
Although, having said that, if you're going to be Crossfiring 5870's and overclocking then yes you may very well need that 1kW power supply. Just think of it though: that's enough electricity to power your kettle :)
thank you for reading :)
indeed i was planning on getting a 650 or 750 mod psu but then i thought might aswell pay the extra then i don't need to buy another 1 in 4/6 months
you can never be to cool :) i want it to be sub zero
my last rig i build went Kaboom because it was 2 hot :( cpu mobo and ram and psu all fried
so i don't want to take any chances
I'd probably get a different SSD, either Intel or OCZ. I don't really think the memory fan is necessary - it'll just make more noise.
The Rampage won't really have any affect on airflow, if you're not getting a combo deal maybe consider the Gigabyte UD5 or the Asus P6TD Deluxe. It does fit in that case (there is a video on youtube of someone trying), but I seem to remember it was pretty tight - I think they had to do some cabling beforehand? I'll see if I can find it.
That case is like a fridge! LOL.
two front mount 120mm, one rear 120mm, and the big boy fan at the top, all controlled by a fan controller built into the rear.
No problem, I'm afraid I couldn't find the video but from memory I think they had to install the 24pin cable before screwing in the motherboard. You might want to bear this in mind if you're doing decent cable management.
I've got similar hardware, you'll love it! :D
oh nice i see you got 2x 5870 viper
was tempted to get a viper
