new rig wont post HELP
  • Thread starter Thread starter 233
  • Start date Start date
233
233
21 Nov 2004
Wishaw
ok just built up my new(to me )rig
spec is
asrock dual sata2
opteron 146
1 gig ram (2x512)
ti4200 agp card
usual drives etc
fires up usual single beep then no output graphics.
pulled the mobo out and swapped with my xp setup system boots fine
any gen guys or tips on what to try first???
nope dont post at all
get a standard beep then nothing not even an output to monitor :(
your board should be using an ami bios ,1 short beep at boot is dram refresh failure, check in the bios that cpu/ram are not out of sync ,timing etc need to be checked aswell ,also a dead cmos battery can give a one beep code.
sorry to be dense but whats that6 mean in english
and the rams fine in my other board :)
its a sort of slightly long single beep
someone on here who has used an opteron should be able to tell use the tmings and ram speed x multi for that chip , ive never used one myself.
what rating is the ram (speed) and the chip supp to be, some ram/chips dont like running out of sync i.e 166 for ram 133 for chip.
*in your bios there should be a setting for the bus speed of the ram/cpu ,make sure the ratio is set to 1/1
