New rig wont power up, help needed!
21 Aug 2007
Just finished replacing my mobo, Ram and cpu, and the new rig wont work.
Got a E4500 2.2ghz processor,
2x1gb of OCZ DDR2 ram,
and an Abit IP35 pro
this i added to my
nvidia 8800 gt,
3 HDD drives,
a creative x-fi fatality soundcard and
a corsair hx520 psu.
The rig will not power up and i am pretty certain everything is plugged in correctly.
The fans blink for a split second but will not power up.
The display on the mobo say 0.1. before i press the power button and 8.2. after i press it.
Anyone got any ideas??
I know all my older stuff was functional so im guessing the problem resides with the new stuff i have picked up or some osrt of compatibility issue.
double check the 24 pin atx connector.....and do you have the extra power connector plugged in too ? (the IP35 may not have one though)
It does have an extra power connector, southwest of the cpu socket :)
Make sure you have the cable plugged in for the 4/8pins northwest of the cpu socket!
