- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Roccat Kone v2 available now. Featuring new eco packaging, improved scroll wheel and the same great 3200 DPI sensor as the original the v2 takes gaming mice to a whole new level.
Take your gaming to the next level for just £47.99 inc VAT.
Stuffed with technology and design innovations, the gaming mouse ROCCAT™ Kone is the only tool to unleash your hidden skills and develop your existing ones to the max. The precise Pro-Aim Gaming Sensor effectively reduces Pick-Up-Flight. It is accompanied by a high-end 6.4 megapixel sensor measuring with 7080 frames per second, loss-free up to a velocity of 20G. 1ms response time, 1000Hz polling rate and the adjustable resolution up to real 3200dpi give you the competitive edge to improve your aiming skills.
- 3200 DPI Pro-Aim Gaming Sensor
- TCU: Tracking Control Unit
- Integrated Turbocore (internal CPU built into the mouse)
- Onboard Memory (128KB) allowing you to save up to 5 gaming profiles
- Ergonomic Hybrid Shape
- Customizable Light System: 5 LED's capable of displaying the full spectrum of colours
- Customizable weighting (5g, 10g, 15g and 20g weights)
BUY NOW
BUY NOW
