New ROG build will not boot!! : (
26 Apr 2013
Scotland
Hey guys, i put my build together today and i'm receiving the dreaded error code '00' on my maximus 5 gene.
After doing some digging, it seems that this could be one of three things..
1. Dead CPU
2. Dead Mobo
3. Rear pins shorting the MOBO
I've removed the motherboard from the case, positioned one DIMM in the A2 slot, removed GFX card and tried booting without the waterblock attached to cpu. Also tried the CMOS reset/remove battery method etc etc..
Still the same error, 00 code (which is reserved in manual).
The motherboard came from an online auction but so did the cpu. I did the delid on the 3770k fairly gently with a thin knife and there is absolutely no visual signs of damage to the core and no visual scratches on the cpu surface.
Could it be that i was too rough with the cpu anyway? Although i don't see damage perhaps there is some? Or more likely a case of a doa mobo that this power seller has tried to flog?
I'm contemplating buying a retail socket 1555 cpu (celeron g550) to test (also, are they compatible??) but i'm worried that if i leave it too long the seller wont accept a return on the mobo.
Ideas?
Discovered that a few pins were bent on the socket! Fixed that but then got the 55 post code. Apparently although this is related to 'memory incompatibility' in the manual. It is actually known to occur for other reasons. One possible cause is a warped motherboard and mine definitely has a slight bend on the i/o panel side.I have a brand new one coming this morning
