Hey guys, been having quite a few issues with my new Ryzen build and wondering if you could share any knowledge.
Specs:
Ryzen 3600
Asus x570-p prime
32gb Vengeance LPX (2x16gb)
rtx2080 iGame
@all stock settings.
1) rtx2080 major graphics issue - White lines.
This is my biggest concern. The gpu is a refurb, therefore likely has no manufacturer warranty (maybe limited time left to send back).
Basically system was fine for first few days, turned on today and 100's of shifting white lines all over display- Bios, windows, everywhere. PC still responsive.
Can restart and sometimes goes back to normal... *NO notification of new driver install/changes*
*Edit - Now the screen *often* changes from ok > weird space invaders logos then either hangs or BSODS.
-I'v tried uninstalling drivers with DDU in safe mode and re-installing new ones.
-I also tried claning all pins and reseating.
-Also tried using 2 different hdmi ports on tv and 2 cables.
When it does this...
-GPU does not show up in HW monitor, device manager says windows disabled it?
-Could this be a potential H/W fault or likely just driver issue? *see pics below*
*maybe related...
-Slow/delayed startup: The pc has always had about a 15sec delay before I even see the initial Asus BIOS screen. Slightly annoying, maybe related?
-No video signal after 'waking up' (pc turns on). I often wake up to my pc whirring away but no display: saybe not entering sleep mode correctly.
2) V.High cpu temps & voltages...
Temps hitting high 60's even when drawing just 30w and over 80c at just 40w: Just browsing Chrome or opening a folder bumps to 1.4v!? Is this normal?
-Good ventilation in case.
-Ambient temp = 20c.
-I have a Kraken x61 280mm AIO to replace the stock cooler with when the new bracket arrives but even if temps halve (doubtful) it'll still be higher than temps of my old 4790k @ 80w / 1.37v.
-I have reseated/pasted cpu with same results.
3) Other minor issues.
-Had 2 system hangs in only 4 days.
-Slow copying (even shows a progress screen for 5mb files) to desktop and generally not 'nippy'.
AS SSD *total* scores halved (random read/write seem ok).
-V. low volume on video players. MPC-HC, VLC, WMP....
Specs:
Ryzen 3600
Asus x570-p prime
rtx2080 iGame
*maybe related...
Your 280 AIO should cope just fine. The stock AMD cooler kept my 3900x at around 80c stock under load.
