My Intel Raptor Lake system keeps on crashing when gaming so I decided to make the jump to AMD but I’m facing major issues with my new build.
I’m using a Ryzen 7800x3d with an MSI X670E Carbon WiFi. I built the system today but it won’t post. If I press the power button on the PC case the RGB RAM lights up and stays on but the fans in the case don’t power on - nothing happens. There is no error code on the motherboard, the Clear CMOS and BIOS flash buttons light up too which means it’s getting some kind of power.
I’ve tried checking the front panel connector is connected properly several times but it must be or else when I press the power button on the case the RGB RAM wouldn’t start to light up.
I’ve unseated and reseated the CPU power and 24-pin ATX several times but it hasn’t made any difference.
I’ve checked the AIO is connected to the Pump header and the case fans are connected to the Sys fan header. I’ve also ensured both are connected to the PSU via SATA/Molex.
I’ve even tried a different PSU to rule out that it’s not a faulty PSU but this hasn’t worked either, I’m getting the same result where the system won’t post but the RGB RAM lights up.
I’ve tried clearing CMOS and flashing the BIOS but neither has worked.
This leads me to believe either it’s a faulty CPU or more likely a faulty motherboard.
I’m at wits end here. I don’t know what to do. Is there something I may have missed to check?
How do I ascertain whether it’s a faulty motherboard or a bad CPU? I did buy both from the same retailer albeit within a day of eachother.
Any advise you can give me would be very helpful.
