Depending on the vehicle speed, and amount of engine power being requested by the driver (full throttle, or part-throttle normal driving),[4] the DSG then upshifts. During this sequence, the DSG disengages the first outer clutch whilst simultaneously engaging the second inner clutch (all power from the engine is now going through the second shaft), thus completing the shift sequence. This sequence happens in 8 milliseconds (aided by pre-selection), and can happen even with full throttle opening, and as a result, there is virtually no power loss.
Downshifting is similar to upshifting but in reverse order, and is slower, at 600 milliseconds, due to the engine ECU needing to 'blip' the throttle, so that the engine crankshaft speed can match the appropriate gear shaft speed. The car's computer senses the car slowing down, or more power required (during acceleration), and thus engages a lower gear on the shaft not in use, and then completes the downshift.
