Samsung has plans to make 32:9 'uberwide' displays, officially called 'double full HD' (DFHD), according to TFTCentral. The panel will be 49-inches wide, with a 3840x1080 resolution. It's basically the equivalent of a pair of 27-inch 1080p displays, built as a single panel. The panel will feature an 1800R curvature, which is far curvier than what we see on 21:9 aspect ratio displays—and the extra curve makes sense given the size of the panel. 60Hz and 144Hz will be available with the option of Freesynd or G-Sync depending on manufacturers choice.
From http://www.pcgamer.com/samsung-to-produce-ridiculously-huge-double-wide-display-panels
Originally announced last year with production supposed to start last year as well but it looks like it's coming this year. Wonder if it'll be of any use, and any good?
