new samsung c34h890 monitor
20 Apr 2010
hi guys,.
i bought a new monitor from amazon uk as oc uk didnt have it and i really like the design ,and if u get one with dead pixel is easy to send it back no question asked,the monitor is a va panel and 100 hz RR for my gaming,work,and daily use.
the only problem is the color is not vivid and picture is not sharp.,as i never had a va panel ,could this be the problem that va panel cant have a good bright color?.
i also check everything but nothing works,so im planing to send it back,
but before i would like to know ur opinion about this.
thank you.
i5 4.2
ms 1070 oc
16 gig ram
A 100mhz monitor is bloody ridiculous! :D
IPS displays have more colour saturation, so it'll probably be something you notice straight away.
The sharpness is another matter though. It depends specifically on how the display panel manufactured, rather than the technology used.
It could be that it has a higher pixel spacing than another display you've used, giving the impression of less sharpness.
