New Satellite setup help
5 Jan 2013
Hi! I'm planning to buy a satellite dish and a receiver in order to have access to:
hotbird 13b - Europe
and
Eutelsat 28A - Freesat UK or Astra 28.2°E - Freesat UK
(I'm based in London)
My plan is to get a 80 cm dish with two LNRs but I'm struggling to decide which receiver/box to buy. My plan would be to have the satellite box working as a receiver as well as a media player.
I've been thinking of the Amiko A3 but would like to have any other suggestions or opinions on this.
Thanks! :)
Have you considered two receivers? A proper Freesat receiver or Sky box (very good epg/guide) then some other receiver for Hotbird.
That was my dilemma. Getting sky's basic package and getting it installed for 12 months is only £268. Roughly the same price as one of those freesat boxes.
I've been into motorised systems since the mid 80s but recently went to a smaller 80cm dish with a DISEQC motor and an amazing VU+ Solo2 receiver.
You probably won't be able to get 28.2 and 13E from the one dish because of the angles so you might as well go motorised.
I can record up to 3 channels at a time (transponder dependent) and I also use the box as a media player.
The VU+ Duo is also a good machine but I wasn't overly impressed with the expensive VU+ Duo2.
Thank you for all the answers!
Is it definitely very difficult to get both satellites with one 80 cm dish?
Which box/receiver would you advise around £150?
How difficult would a DIY installation for a motorised system be?
Thank you! :)
Thank you! :)
Normally the twin LNB goes between 19E and 13E which is a 6 deg angle but you want to go 15 deg which I doubt will work.
VU+ have just made a receiver called the Zero but it uses an external hard drive.
There is a VU+ Solo but only records 1 channel.
(I'm a VU+ fanboy).
What you need is a receiver that gets plenty of support and VU+ are the best supported.
DISEQC makes the job very easy.
You basically point the dish with the motor set on 0 to South.
Choose a Freesat channel on 28.2 and the dish should move to that satellite but you will now need to adjust the dish/LNB to get a signal.
Once you've got the signal the motor will know all the other satellites.
There's a bit more to it than that but that's the basics.
I only use satellites 28, 23, 19, 16, 13, 5 and 1W.
Hi Dimple!
Thanks for the advice!
I wasn't planning on using a twin LNR but two LNRs in a bracket, on the same dish.
Would that be feasible for the 2 satellites?
Thank you!
There's a guy in Edinburgh who says he gets 28.2, 19 and 13 on a fixed 80cm dish so it must be possible.
Why are you interested in Hotbird?
Oh and they are LNBs.
I know the VU+ Duo2 has but it is very expensive.
You are probably best asking on here because I will just shove you up the VU+ path with a DISEQC motor.
