New second monitor
15 Aug 2007
My old monitor has just died out on me so I'm currently without a 2nd monitor. I am unsure if I should get something similar in specs to the P2450 which I currently own or get something better which will hold its own better in the future.
The only thing that's stopping me from buying a better spec'd screen is that I'd like both screens to be as identical as possible in terms of visuals so it puts me off buying a higher res screen which I will want in the future.
*Just checked the 24" screens* It seems like 1920x(1080/1200) is all there is, so I guess there's no higher resolution screens... so I guess this has turned into the best companion to the P2450 I can get, any advice?
Seems like http://www.overclockers.co.uk/showproduct.php?prodid=MO-071-IY would fit the bill, looks pretty decent.
