Hello,
Just purchased a new setup and having troubles getting the system going. The setup is as below:
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit
Asus P5B Deluxe (Socket 775) PCI-Express DDR2 Motherboard
BFG GeForce 8800 GTX OC 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Hiper HPU-4K580-MK Type R 580W Modular ATX2.2 PSU
The PSU I know is ok, as this was the power I used for my old rig (and tested it again just to make sure after I was having problems). When I plug the power cords onto the motherboard and turn the power on, the ASUS 'Blue' light comes on indicating that the motherboard is receiving power. 1 Ram chip is already on at this time, and ofcourse the cpu is seated and its heat sink is securely on. When I try and boot the system now, nothing happens, no spinning of fans, and no indication the system is trying anything. I have tried removing everything bar the cpu, and still no power.
So is the motherboard faulty do you think? The blue light on it is certainly misleading if it is. I've tried shortening the power pins on *** board itself to rule out the Case Power Button, but to no avail.
I have no way of testing if the Gfx card is faulty, and would the ram function in the old DFI Lanparty nf3 that sported my a64 3700?
Thanks
Thanks
