New speakers. Stick with onboard sound?
27 May 2003
I've been Looking at upgrading my PC speakers to something like the Corsair SP2500.
However I currently use my mobo's on-board sound (Asus M4A88TD-V EVO/USB3 with onboard Realtek HD Audio.)
I'm currently using Creative I-Trigue 2.1 3300 (9w RMS and 25w sub) and am wondering if I'd need to get a dedicated sound card to make best use out of the SP2500 set.
I'm after clarity as much as anything as the I-Trigue set is loud enough.
Used mainly for music and films.
Ta
I'd grab a sound card, even if it's a budget Xonar DG/DGX. The board you have uses ALC892, which isn't among the better onboard audio offerings. If you can spend more, then it would be worth it. A Xonar D1/DX, or a Creative Soundblaster Z OEM for around £50-£60, would be ideal.
The Xonar DG should be perfectly fine :)
