- 13 Aug 2009
- widnes
i think we should have a sticky with the 5850, 5870 cards which cases will fit them as i think the forum will be hit with them cos the cards are huge
A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels.
Yes, great idea because they are so much longer than nvidia's top end cards that have been out for the past 2 years.....
well if it doesnt fit..... make it fit!!!!
