- 22 Mar 2004
I'm in a bit of a quandry.
I have a budget of around £1500 - £1600 ish to replace my 5 years old I5 720 @ 4ghz with a 7970 system. Using it mostly for gaming and home cinema.
I was looking at:
8Pack Approved - Elite Tier SkyLake Bundle: Intel Core i7-6700K @ 4.50GHz, Asus Z170 Maximum VIII Hero, 16GB DDR4 3000MHz, 256GB NVMe PCI-E M.2 SSD, OcUK Techlabs Extreme 240mm Hydro CPU Cooler
Zotac GeForce GTX 980Ti AMP Edition 6144MB GDDR5 PCI-Express Graphics Card (ZT-90503-10P)
Samsung 1.0TB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E1T0B/EU)
Fractal Design Define R4 Midi Tower Case - Black
Which comes in at around £1670 and using my existing windows copy, 750W corsair PSU and 27" 1080 screen (upgrading when i get more monies).
But then I though it might be a little overboard for what I'm using it for and wondered the budget would be better spent on getting a lower specced full system and get a new 1440 monitor, and donating the existing system.
I may be way off base, but I'm not really up to speed on the newer tech but would like the system to last another 5 years.
Thanks for any and all advice.
I was looking at:
