- 30 Aug 2011
Hi all,
I'm a developer looking to rebuild my main development machine which is about 4 years old now (got a Core i5-2500 at the time), nothing particularly wrong with it, but enough time has passed that I think a new system would be a big upgrade!
My main priorities are:
- maximise single-thread performance, which software dev stuff is usually bottlenecked on, no need for loads of cores
- I do some graphics work so a modern high-end GPU (but probably won't be gaming on it)
- quiet system, not too much fan noise
- high-spec but not extreme, probably won't bother overclocking it
- only replacing the tower, keeping same keyboard/mouse/display etc
Here's my spec so far:
Case: https://www.overclockers.co.uk/fractal-design-define-s-midi-tower-black-ca-028-fd.html
PSU: https://www.overclockers.co.uk/be-q...0w-80-plus-silver-power-supply-ca-092-bq.html
Mobo: https://www.overclockers.co.uk/asus...cket-1151-ddr4-atx-motherboard-mb-648-as.html
CPU: https://www.overclockers.co.uk/inte...ocket-lga1151-processor-retail-cp-581-in.html
CPU cooler: https://www.overclockers.co.uk/be-quiet-shadow-rock-lp-low-profile-cpu-cooler-120mm-hs-011-bq.html
RAM: https://www.overclockers.co.uk/cors...hannel-kit-black-cmk16gx4m2b30-my-445-cs.html
SSD: https://www.overclockers.co.uk/sams...olid-state-drive-mz-75e500b-eu-hd-192-sa.html
Graphics: https://www.overclockers.co.uk/msi-...ddr5-pci-express-graphics-card-gx-32g-ms.html
Just want to check it is all compatible, will fit in case, choices make sense etc. Does this look like a sensible build?
