New system build help/opinions plz
12 Aug 2012
hi all, im now starting to/about to order parts for a new system and i would like your input please, pertically on the water cooling side as ive never had anything to do with that. i will be using it for work, photoediting and some games, the spec ive got at the moment is:-
cpu
Intel i7-5820K Extreme Hex Core CPU Processor (3.30GHz, 15MB Cache, 140W, Socket 2011-V3, 28 Lanes PCI Express Generation 3)
motherboard
Asus X99-S ATX Motherboard (5x PCI Express 3.0, DDR4 Quad Channel, Socket 2011)
video card which at a later date will add a second
MSI NVIDIA GTX 970 Gaming Twin Frozr HDMI DVI-I DP Graphics Card (4GB, PCI Express, DDR5, 256 Bit)
psu
Corsair CP-9020062-UK RM Series RM1000 80 Plus Gold 1000W ATX/EPS Fully Modular Power Supply Unit
case
Corsair CC-9011022-WW Obsidian Series 900D E-ATX Super Tower Performance Windowed Case for Computer - Black
ram
G Skill Ripjaws 4 F4-2400C15Q-16​GRK 16GB Memory Module Kit with Heatspreader - Black
water cooling:
pump
EK Water Blocks EK-D5 Vario X-TOP - Acetal (incl. pump)
https://www.overclockers.co.uk/showproduct.php?prodid=WC-409-EK&groupid=962&catid=2141
reservoir
Aqua Computer Aqualis XT 150ml
https://www.overclockers.co.uk/showproduct.php?prodid=WC-153-AQ&groupid=962&catid=2133&subcat=2135
cpu block
Aqua Computer Cuplex Kryos PRO - Socket 2011
https://www.overclockers.co.uk/showproduct.php?prodid=WC-091-AQ&groupid=962&catid=1519&subcat=2286
gpu block
EK Water Block EK-FC970 GTX - Acetal
https://www.overclockers.co.uk/showproduct.php?prodid=WC-707-EK&groupid=962&catid=1520&subcat=2885
What size fittings and pip would i need?
thankyou jay
Hi,
Firstly that CPU doesn't fit the board. You need a 5820K.
There are better quality PSUs such as EVGA G2 or Superflower.
And the case, well Phanteks do cases that can eat up water cooling parts.
What drives do you have?
Intel i7-5820K Extreme Hex Core CPU Processor (3.30GHz, 15MB Cache, 140W, Socket 2011-V3, 28 Lanes PCI Express Generation 3) that one,? had a few different things on my wish list just deleted them
I've seen a few Youtube vids about that Phanteks and the amount of rads etc it can take inside is impressive.
Instead of going full water cooling from the start.
How about just using a H100i GTX just to cool the CPU initially, then work up to a full custom loop.
just ordered the case if all go ok coz ive never used them before ill get the rest ordered up, what size tubing should i be aiming for?
1/4" fittings is usually 10/16mm tubing.
But custom water cooling is not something I specialise in.
Which colour case did you get? all I do know is you might want to rethink the colour of the cpu block+res as black tends to go with everything then pick a dye to match the board accents or something.
