- 16 Jan 2013
- Stranraer
Hey Folks so as the Tile suggests ive build my new System Everything is working great Windows installed Flawlessly as well as the GPU,Monitor,Chipset drivers etc although i have a big problem when i Go into the Display settings the max Resolution i can Select is 1920x1080 my 34 inch Ultra-wide is 2560x1080
Ive Attached Photos below so you can see what im on about Ive Also installed the Windows 10 Monitor Driver to see if that would help im using the AMD 17.10.2 Driver and my Graphics card is a HD 7850 2GB using a HDMI to DVI-D adaptor as that worked with my Previous GPU and Windows 7.
Also when i go to create a Custom Resolution it says my Display is not Compatible
