New system build
Suspended
17 Mar 2006
A friend has asked for a new system, under £1000. It's going to be a family PC, probably gaming as well, but also for capturing footage off analogue camcorder and to convert and then burn onto DVD-R. I have no idea about capture side of things. So far I've got the following in my basket.
CP-127-IN Intel Core 2 DUO E6400 "LGA775 Conroe" 2.13GHz (1066FSB) - Retail (CP-127-IN)
£154.95 £154.95
MB-141-AS Asus P5LD2-SE Intel 945P (Socket LGA775) PCI-Express Motherboard (MB-141-AS)
£65.95 £65.95
MY-059-CS Corsair 1GB DDR2 XMS2-5400 TwinX (2x512MB) (MY-059-CS)
£64.95 £64.95
GX-044-CO Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-044-CO)
£144.95 £144.95
HD-070-WD Western Digital Caviar SE16 320GB 3200KS SATA-II 16MB Cache - OEM (HD-070-WD)
£64.95 £64.95
CD-038-PO Pioneer DVR-111DBK 16x16 DVD±RW Dual Layer ReWriter - (Black) OEM (CD-038-PO)
£21.95 £21.95
HS-017-AR Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
£14.95 £14.95
CA-037-TT Thermaltake VC3000BNS Armour Jr SuperMidi Tower - Black (CA-037-TT)
£49.95 £49.95
CA-025-EN Enermax Liberty 500W ELT500AWT ATX2.2 Modular SLI Compliant PSU (CA-025-EN)
£59.95 £59.95
Subtotal £642.55
VAT £112.45
Total £755.00
Not too sure on the case, would like something similar with decent amount of cooling (12cm front and back) without a door, in black. I have no idea what software you need to do capturing/converting. Any ideas for capture/videocard (combo?)
