I'm going to be building a new system this year to replace my ageing one - a AMD Barton 2500 (1.8ghz) cpu.
The cpu I am thinking of building my new system around would be something like the Intel Core 2 Duo E8400 Wolfdale 3.0 or 3.16Ghz chip.
I have read quite a few posts and the reviews of the 3.0Ghz Wolfdale chip which seems quite popular and some people have reported getting over 4Ghz just overclocking it on air.
Can anyone tell me how much more you'd be able to get out of a chip like this by using water cooling instead and how much you'd need to spend to get that extra?
I have built a couple of my own systems in the past but I have never overclocked them so am new to overclocking as well as water cooling.
I guess I am trying to find out how much extra I could get from the cpu from spending a couple hundred on water cooling instead of just a hundred or so on an air cooler?
The cooling I was just thinking of for the cpu nothing else at the moment.
I don't know what dual loop, single loop, short loop etc mean? If you have any useful links on overclocking especially water cooling and how you would put a water cooled system together I'd appreciate it.
If anyone has this Wolfdale chip and can give me their advice what to expect from air and water cooling I'd appreciate it. Also if you can tell me what other components you'd recommend I match up with this for best overclocking e.g. mobo, memory etc I'd like to hear your opinion of what to consider.
Thanks,
John
Thanks,
John
