new system build
10 Feb 2010
Biggin Hill
Hi Guys
Great forum and loads of good info here for sure thank you, but thought it time i posted, i been thinking of building a new system over the coming months and im going to get a few bits each month untill its finished, im going to include what i think ive decided on, any comments on improvements and performance i can expect would be great as this is the first build ive attempted.
Also will there be any unexpected problems anyone can see with this rig.
Thanks in advance
tony
Asus P6T SE, Intel X58, Sok 1366, PCI-E 2.0 (x16), DDR3 2000/1866/1800, SATA 3Gb/s, SATA RAID, ATX
BX80601920 - Intel i7 920, D0 SLBEJ S1366, Bloomfield, 2.66 GHz, QPI 4.8GT/s, 8MB Cache, 20x Ratio, 130W, Retail
RC-1100-KKN1-GP - Coolermaster RC-1100 V2 Cosmos S (Sport) Black Full Tower Case w/o PSU - NEW In Stock
950W Corsair CMPSU-950TXUK, SLi, High Performance Power Supply - massive 78A single +12V rail
TR3X6G1600C9 - 6GB (3x2GB) Corsair XMS3 DDR3, PC3-12800 (1600MHz), 240 Pin, Non-ECC Unbuffered, CAS 9-9-9-24
Creative X-Fi Titanium Fatal1ty Champion*
SH-B083L/RSBP - Samsung Blu-Ray Combo Player
1TB Samsung HD103SJ Spinpoint F3, SATA 3Gb/s, 7200rpm, 32MB Cache, 8.9 ms, NCQ, OEM
HD-585A-ZNBC - 1GB XFX HD 5850 Black, PCI-E 2.0(x16), 4000MHz GDDR5, GPU 765MHz, 1440 Cores, DP/ 2x DL DVI-I/ HDMI
pretty similer spec to what im building , also i dropped p6t out for a rampage 2 extreme. also the 950 isnt really needed unless your runing 2 cards but then again a 950 wat maybe needed a lot more in the future so getting it now could be a good idea, but yeh i run it all on corsair tx 650w
The psu is overkill and not modular, try the 850hx.
The rest of that will make one very fast pc.
Still undecided between the intel i7 chip and the phenom way? I've always been amd so I guess habbit plays a big part but intel does look the better option
views on this for me would be great ;-)
