New system check - ~£3k build
19 Jul 2015
Hi all, looking for a bit of advice on this pre-build. Budget of ~£3k for the tower - all sorted for peripherals. Typically play at 3440 x 1440 (modded Skyrim, Fallout etc.).
My basket at Overclockers UK:
  • 1 x OcUK Tech Labs Coffee Lake Pro Gaming Configurator = £3,019.69
    • Motherboard:Gigabyte Z390 Aorus Pro Intel Z390 (Socket 1151) DDR4 ATX Motherboard
    • Processor:Intel Core i9-9900K 3.6GHz (Coffee Lake) Socket LGA1151 Processor - OEM
    • CPU Cooler:NZXT Kraken X52 AIO Water Cooling Unit - 240mm
    • Memory:Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD416G30
    • M.2 Solid State Drive **For Operating System If Selected**:Samsung 970 EVO Polaris 500GB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive
    • Solid State Drive 1:Unwanted
    • Solid State Drive 2:Unwanted
    • Mechanical Hard Drive 1:Seagate BarraCuda 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - *System Stock*
    • Mechanical Hard Drive 2:Unwanted
    • Optical Drive **Please Check Chassis Support**:Unwanted
    • Power Supply:Seasonic Focus Plus 850W 80 Plus Platinum Modular Power Supply
    • Soundcard:Unwanted
    • Network Adapter:Unwanted
    • Case Lighting:Unwanted
    • Operating System:Microsoft Windows 10 Home Advanced - Systems
    • Security Software:Unwanted
    • Build Time:Standard Build Systems - Dispatched in approx 7 working days
    • Headset:Unwanted
    • Keyboard:Unwanted
    • Mouse:Unwanted
    • Speakers:Unwanted
    • Monitor:Unwanted
    • Gaming Chair:Unwanted
    • Case:Phanteks Enthoo Luxe Glass Midi Tower Case - Black
    • Graphics:Asus GeForce RTX 2080 Ti ROG Strix OC 11264MB GDDR6 PCI-Express Graphics Card
    • Graphics 2 (SLI/Crossfire):Unwanted
Total: £3,033.79 (includes shipping: £14.10)​
Hi
I would make a couple of changes.
Try and swap out the cooler for a bigger rad. A 360mm AIO would be better as the 9900K runs hot. The Alphacool Eisbaer LT 360 would be my suggestion.
You could drop the PSU down to 650W. The Focus Gold would save you a bit there.
Maybe stick a 2TB Seagate HDD in there as well as it is only an extra £21 over the 1TB version.
Total: £205.44 (includes shipping: £10.50)
Also looks like the Asus gpu is out of stock so I would check on availability, as it will hold up the build otherwise. Other option is to go with something that is in stock.
Cheers for taking a look, Lee. Good shout on the cooler will get in touch with the team to see if its possible to get that one as part of the config. May just do the build myself otherwise.
  • 1 x OcUK Tech Labs Coffee Lake Pro Gaming Configurator = £2,670.78
    • Motherboard:Gigabyte Z390 Aorus Ultra Intel Z390 (Socket 1151) DDR4 ATX Motherboard
    • CPU Cooler:be quiet! Dark Rock Pro 4 CPU Cooler
    • Power Supply:Bitfenix Whisper M Series 850W 80 Plus Gold Modular Power Supply
    • Headset:Unwanted
    • Keyboard:Unwanted
    • Mouse:Unwanted
    • Speakers:Unwanted
    • Monitor:Unwanted
    • Case:be quiet! Dark Base 700 RGB Midi Tower Case - Black Tempered Glass
    • Graphics:Zotac GeForce RTX 2080 Ti AMP Edition 11264MB GDDR6 PCI-Express Graphics Card
Total: £2,684.88 (includes shipping: £14.10)​
Would personally build yourself
Can get easily £500 knocked off self build and less flash, but went with some of the best and visual looking g nice with Corsair
Total: £2,917.97 (includes shipping: £14.10)​
