New System Problems, Crysis FPS Problems on a 4870x2 !! - Please Help !!
Hi there, just yesterday, I built a PC with the following specs:
Intel Q9450 at 2.66ghz
Sapphire 4870X2
4GB OCZ 1000MHZ Ram
500GB Seagate HDD
Thermaltake 750w Modular PSU
Antec 900 Case
Arctic Cooling Freezer 7 Pro CPU Cooler
Windows XP Professional 64 Bit
My problem is, that I've installed Crysis (A very demanding PC game) and I ran the GPU benchmark. By Running this on Direct X9 Modded to Very High with 0xAA, I am getting an FPS from 22-29, on a 20" monitor at a resolution of 1680x1050. And while playing the game, my FPS is ranging from 50-20 !! Now I didn't expect a constant 60+ FPS, but c'mon, I'm using Direct x9 here, and am getting REGULAR framerates of 20 !!, sometimes lasting a good 20 minutes. I've got some possible theories listed below, I'm hoping you guys could lead me to the right direction as to what I should actually do.
Extra Information: On the Catalyst Control Center (Version 8.12) It states in the hardware information, that my system has 1 primary adapter, the 4870X2, and then 1 disabled adapter, and it shows my 4870x2 again. I will show you a screenshot of what exactly is happening.
http://e.imagehost.org/0482/Primary_Adapter.jpg
And then If you scroll down.....
http://e.imagehost.org/0529/Disabled_Adapter.jpg
Also Take Note of the fact that in the device manager, I can see two 4870x2 and none of them have error logos besides them.
Also, when I first made the PC and booted it up, it said 'verifying DMI pool data' and then said successful, please install O/S etc. Then the second time, it just hung on 'verifying DMI pool data'. Then my friend (via IM) told me to change some things on the BIOS (one thing being to boot from the disk drive first, then hard disk), the verifying DMI pool data didn't say 'successful' and go away, but I was able to install my O/S. Now when I boot up, it shows all of these settings which I don't understand, the verifying pool data thing hangs for a second, then it says 'boot from cd/dvd' then the O/S starts.
These are my theories as to what may be wrong, please suggest otherwise if this is the case.
1). My CPU is bottlenecking the GPU, so I must therefore overclock
If this is the case, does anyone know any O/C'ing methods that don't involve permanent changes in the BIOS ? Also, has anyone here got a Q9450, please tell me how much you O/C'ed yours (Remember that I'm not using a stock cooler here, but then again, my cable management inside is awful at the moment
2). XP does not work well with Multi GPU based graphics cards, and I should therefore intall Vista
3). Something in the BIOS needs to be changed.
4). I hope and pray that this isn't the case, faulty equipment
Please respond quickly, as I'm starting to panic atm. Please remember that I am a complete n00b to this stuff, and that this is my FIRST EVER BUILD. Apologies if this is in the wrong section.
Sapphire 4870X2
4GB OCZ 1000MHZ Ram
500GB Seagate HDD
Antec 900 Case
)2). XP does not work well with Multi GPU based graphics cards, and I should therefore intall Vista
