Hi guys, i need help, i recently managed to buy a HP Workstation wx6400 with dual intel xeon 3.0GHz chips, 4 GB RAM 80GB hd. i paid £200 for this and chose this over a new build with an AMD bulldozer 6x setup. 1.Was this my first mistake* i should probably say that im a student so will be using the typical student software, but also a lot of AutoCAD and CAD based programs, i picked up twin Dell 19inch monitors for £70 and chose them over 2x 20in samsung syncmaster for £110 2. Was this also a mistake? then due to the tiny hdd and i tend to download quite a bit, i bought a samsung f3 1TB internal HD for £70 3. is this any good and is it compatible? and now im contemplating RAM, the motherboard can take up to 16GB but i think 8GB would be enough, plus my budget is reaching the bottom of the pool and i have seen some RAM for £20 or so but im not sure if i should wait and buy a more high spec ram or would it even matter (by that i mean will i even notice) because ill have 8GB so it should handle most things i throw at it, shouldnt it? sorry to write such a lengthy post but i really need the help n.b i have had a little bit of a rush of blood to the head and bought all of this in a little bit of a frenzy*alt=":hammer:" />*i know im dissapointed in myself but come on.... who hasnt cheers guys*
