Hi guys,
I just ordered a load of new bits from OC which should be coming tomorrow, really excited about the spec I'm getting especially for such a low price.
Anyway, I have a couple of questions.
Firstly with regards to over clocking - I ordered the OC barebones primo 520i which has a Gigabyte H61 motherboard. Now from what I read the H61's arent favoured for overclocking. But does this mean I wont be able to overclock at all? My processor is a Core i5 2500k, I was hoping to push the speed a bit, maybe just 10%. Will I be able to do this with that motherboard?
I've ordered the Asus Axe Square limited edition cooler which I assume will be able to handle a bit of overclocking.
My second question is about the cooler specifically, I have since read a review of it where it basically failed, but the reviewer was unable to determine if he had a defiective unit as it had an uneven base. Does anyone have any experience with this cooler? Is it any good, and will it cope with a little over clocking?
I'm new to the forum, but not a total novice at over clocking as I did overclock my previous q6600 on an air cooler with good success.
Any advice would be greatly appreciated.
Thanks
Thanks
