New system spec check
8 Mar 2006
All
Please can you just cast your eyes and expertise over these parts for my first system build.
System is for "light" gaming (i.e. Rome Total War etc) for the next few years:
AMD Athlon 64 3700+ San Diego 90nm (Socket 939) - OEM (CP-150-AM)£119.95
Asus A8N5X nForce4 (Socket 939) PCI-Express Motherboard (MB-120-AS)£49.95
OcUK Value 2GB (2x1GB) PC3200 184pin DDR Memory Dual Channel Kit (MY-006-OK) £89.95
Samsung SH-W162C 16x16 DVD±RW Dual Layer ReWriter (Black) (CD-068-SA)£19.95
Antec SLK3800BUK Black Quiet Midi Tower Case - 400W SmartPower PSU (CA-048-AN) £51.95
PowerColor ATI Radeon X800 GTO 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail (GX-054-PC) £59.95
Arctic Cooling Freezer 64 Pro CPU Cooler (Socket 754/939/940) (FG-000-AR)£12.95
Arctic Silver 5 Thermal Compound (3.5g) (AC-000-AC) £2.95
Seagate Barracuda 7200.9 NCQ 120GB ST3120813AS SATA-II 8MB Cache - OEM (HD-054-SE) £44.95
Total is around £550 with VAT
Thanks
It all looks good but as fenderbass86 says you might as well go for Geil Value since it is the same price, I'd also consider the NEC 4551 for the DVDRW but it is a bit more expensive.
