New system speed check-ok?
Suspended
17 Mar 2006
AMD Athlon X2 4400+
Asus A8R32 MVP Deluxe motherboard, auto for all settings (memory etc) flashed to latest bios
ATI X1900XT 512MB stock OC settings
Corsair XMS 3200 2GB
Windows XP SP2, 6.3 ATI drivers, usual apps, avg..
3Dmark2003 pro, 1025x768 default settings
9994
Benchmark
Width 1024
Height 768
Anti-Aliasing None
Post-Processing No
Texture Filtering Optimal
Max Anisotropy 4
Vertex Shaders Optimal
Force PS 1.1 in GT2 & GT3 No
Repeat Tests Off
Fixed Framerate Off
Comment
3DMark Score 9994 3DMarks Game Tests
GT1 - Wings of Fury 288.5 FPS Game Tests
GT2 - Battle of Proxycon 60.9 FPS Game Tests
GT3 - Troll's Lair 51.8 FPS Game Tests
GT4 - Mother Nature 82.6 FPS Game Tests
CPU Score 1116 CPUMarks CPU Tests
CPU Test 1 121.8 FPS CPU Tests
CPU Test 2 20.3 FPS CPU Tests
Fill Rate (Single-Texturing) 3407.1 MTexelss Feature Tests
Fill Rate (Multi-Texturing) 9136.6 MTexelss Feature Tests
Vertex Shader 61.4 FPS Feature Tests
Pixel Shader 2.0 155.0 FPS Feature Tests
Ragtroll 26.9 FPS Feature Tests
No sounds 68.5 FPS Sound Tests
24 sounds 60.3 FPS Sound Tests
60 sounds 0.0 FPS Not supported Sound Tests
System Info
Version 3.6
CPU Info
Central Processing Unit
Manufacturer AMD
Family AMD Athlon(tm) 64 X2 Dual Core Processor 4400+
Architecture 64-bit
Internal Clock 2205 MHz
Internal Clock Maximum 3000 MHz
External Clock 200 MHz
Description Radeon X1900 Series
Manufacturer ATI Technologies Inc.
Total Local Video Memory 512 MB
Total Local Texture Memory 512 MB
Total AGP Memory 256 MB
Driver File ati2dvag.dll
Driver Version 6.14.10.6601
Driver Details 8.231-060221a1-030895C-ATI
Driver Date 21022006
VGA Memory Clock 0 Hz
VGA Core Clock 375 KHz
DirectShow Info
Version 6.05.2600.2180
Memory Slots Installed Enabled Size Form Factor Frequency Slot Manufacturer Type Type Details Enabled Size Total Bit Width Data Bit Width
1024 MB DIMM 400 MHz DIMM0 [BANK0] Manufacturer0 DDR Synchronous 1024 MB 64 b 72 b
1024 MB DIMM 400 MHz DIMM1 [BANK1] Manufacturer1 DDR Synchronous 1024 MB 64 b 72 b
0 B DIMM 0 Hz DIMM2 [BANK2] Manufacturer2 0 B 0 b 0 b
0 B DIMM 0 Hz DIMM3 [BANK3] Manufacturer3 0 B 0 b 0 b
Motherboard Info
Supported Slot Types ISA, PCI
Manufacturer ASUSTeK Computer INC.
Model A8R32-MVP Deluxe BIOS Version 311
Processes Name PID Memory Usage
System Idle Process 0 28 KB
System 4 236 KB
smss.exe 816 420 KB
csrss.exe 872 3372 KB
winlogon.exe 900 4116 KB
services.exe 948 5 MB
lsass.exe 960 1412 KB
ati2evxx.exe 1132 1872 KB
svchost.exe 1152 3456 KB
svchost.exe 1224 4232 KB
svchost.exe 1396 18 MB
svchost.exe 1440 3060 KB
svchost.exe 1552 2792 KB
spoolsv.exe 1640 4408 KB
ati2evxx.exe 1804 2776 KB
explorer.exe 1872 10 MB
CLI.exe 1980 6 MB
avgcc.exe 1988 9 MB
RTHDCPL.EXE 1996 21 MB
avgamsvr.exe 212 5 MB
avgupsvc.exe 252 2056 KB
avgemc.exe 284 6 MB
oodag.exe 344 3916 KB
wdfmgr.exe 660 1632 KB
CLI.exe 2100 5 MB
CLI.exe 2108 6 MB
Opera.exe 400 8 MB
svchost.exe 3988 3972 KB
3DMark03.exe 1128 30 MB
wmiprvse.exe 4088 6 MB
Logical Drives Drive Letter Label Type Capacity Available
C Hard Disk 298 GB 276 GB
D Western_Digital Hard Disk 75 GB 9 GB
E IBM_60GB Hard Disk 57 GB 17 GB
F CD-ROM 0 B 0 B
G OFFICE10 CD-ROM 449 MB 0 B
ps I have "mass storage controller" in device manager with yellow exclamation, what device is this?
1st.....dont post so much crap, no1 is gona read all that rubbish
2nd....u sure u ran 3dmark03 and got 9000 odd? or was it 05, coz my scores with a 7800gtx 256mb are:
3dmark03: 17500
3dmark05: 8386
3dmark06: 4058
just to put yours in perspective
if your getting 9000 odd in 03 then theres sumin wrong coz your card should **** all over mine
No swearing, read the FAQ.
Otacon
squiffy said:
weird. I get around 9800 in 3mark 2005.
Squiffy, I get 8700 ish in 3do5 and over 18000 in 3do3 so I think you are either using 3do5 or your BIOS isn't set up right? :confused:
Nope, definetly using right 3dmark, have all three installed (03,05,06) made sure correct one as I wrote it down.
I don't have AVIVIO driver installed.
Which setting is for CAS 2 (I have CAS 2 memory) I could be running on CAS 3.
San Andreas is smooth at 1600x1050 32bit, highest detail. I also have Fear. If I were getting 9000 in 3dmark 03 wouldn't SA be unplayable? ok just increased PEG to "faster" and now 10050 in 3dmark 03.
edit right just uninstalled and reinstalled ATI drivers, currently running- seems faster, trolls lair girl hair in the closeup was juddery (in the 3D test), now smooth. Yup now gets in 17300 in 3dmark 03 I was messing around in ATI quality panel, that probably effected 3d settings (perhaps AA)
That's more like it :D
Still some more there though. ;)
