Looking to build a new system and would appreciate any thoughts or advice in filling in some of the gaps.
User Type
- I tend to build a decent system upgrade it slightly during its life then build a new system 2 - 4 years later.
Usage
- Gaming typically MMO, FPS and RTS.
- General entertainment - music, movies and browsing etc.
- Occasional business - document production and email.
- Often left on for several days when downloading.
Budget
-V loose and flexible ~£950 Ex VAT
Components Selected or Selection Criteria
-CPU - E8400 is my initial thought but any thoughts?
-Motherboard - Open to suggestions - I have had good experiences with Asus motherboards previously so perhaps a slight inclination to continuing with this manufacturer. Ultimately I tend to like spend in this area so I am looking for advice on the better premium models at present.
-RAM - Open to suggestions - looking for a reasonable performer and good match for CPU without stepping into extremist territory / pricing.
-Graphics Card - Open to suggestions was looking at the 8800 and 9600 cards, may stretch a bit further but I doubt I would spend more than a £150 Ex VAT in this area without excellent justification.
-HDD - Samsung SpinPoint F1 750GB SATA-II 32MB x 2 (1 OS and applications, 1 games and video).
Monitor - Dell Ultrasharp 2408WFP – My only concern is the 1920 x 1200 optimum resolution, as I play a lot of games and doubt I will be able to run many of them at this res. Anyone with experience here got any thoughts?
-Case and Cooling – I have no desire to see inside my PC once built. I am looking for minimal noise, plenty of space and predominantly black colour scheme. With regard to a cpu cooler minimum noise is my preference.
-PSU – Probably best spend here my current system ended up with 7 hard drives. I doubt this one will get up to 5 hard disks though. Enermax have served me well previously but I am open to suggestion. Anyone got a link to a good calculator to determine what real wattage I should aim for.
-Sound Card - Creative Sound Blaster X-Fi Xtreme Gamer Fatal1ty Professional not had a sound card since Pentium2 days but people do keep raving about them so thought I would return to the fold and give the above a try. I currently output via s/pdif to a 5.1 AV receiver amp and like the clean sound this gives. Unsure if this is the best way to output going forward or if I should switch to more traditional cables
Appreciate any answers or advice you can provide.
User Type
Usage
Budget
