Hi All,
I have recently bought these components from OC:
E8400 Wolfdale CPU
Abit IP35 Pro MOBO
OCZ 600W PSU
Thermalright SI-128 Cooler (with a 120mm fan)
Sony 3.5" FDD
Seagate 80gb SATA-II HDD (on SATA 1)
Samsung F1 750gb SATA-II HDD (on SATA 2)
4gb Corsair DDR2 6400C5
Sapphire 512mb HD 4870 GFX
All in an Antec Nine Hundred case.
My one cannabalised component is my multi-function Samsung DVD writer.
The machine boots successfully and winxp begins an install with correct recognition of all components. Once the drives have been partitioned and formatted (NTFS) winxp continues to install until it hits "39 minutes left" during the "device installation" section of install. The PC then reboots back to drive selection, partition and format.
I have tried 1gb and 2gb of RAM using all the stick combinations and I have also tried removing the FDD and using only one or other of the HDD's.
I am installing from an original XP disk and license with my micosoft SP2 disk ready for when I need it.
There are no net connections yet or any other form of network connection.
Does anyone have any ideas?
Regards
TDyl
E8400 Wolfdale CPU
Abit IP35 Pro MOBO
OCZ 600W PSU
Sony 3.5" FDD
Regards
TDyl
) for a while to check for any errors.
