I have just finished building my system, it boots into Bios
I have set the boot sequence as 1st Pioneer DV RW (which is IDE and i have tried moving the jumper from master to cable select)and then 2nd the Sata HD. But although it recognises the cd rom ( its name apperas on the screen in green writing)
I have tried setting the floppy as 1st boot with a win 98 start up disk in but it still just keeps giving me the "Disk boot failure" screen.. I must be doing something stupid or i have a cable in wrong..Any advice?
Ps Tried swapping cdrom . it immediattly recognised the hitachi but still no boot...also i am using ps2 keyboard and mouse... But why wont it even boot to the flopppy????
Edit.... It will boot from A-Bits own CD rom and asks if i want to make a driver disk. But i am not running raid so do i need one?
also its now loading vista but it wouldnt load XP.. weird? I have tried a different copy of XP and it seems to be accepting that now..
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB)
Arctic Cooling Freezer 7 Pro CPU Cooler
Abit IP35 Pro (Socket 775) PCI-Express DDR2 Motherboard
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2(1.9-2.0 Volts-CL 4-4-4-15)
Western Digital Caviar SE16 500GB SATA-II 16MB Cache
Pioneer DVR-112DBK 18x18 DVD±RW IDE Dual Layer ReWriter
EVGA GeForce 8800 GT 512MB Superclocked- GDDR3 HDTV/Dual DVI (PCI-Express) -
Lian-Li PC-7 PLUS II Aluminium Midi-Tower Case
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU
Edit/Delete Message
Edit/Delete Message
