New system
29 Nov 2006
Hello all!! lol
Im guuna ask you all for your input here im gunna build myself a new machine but dont know what good for the money and wont have me updateing in 6 months time cause believe me ive not updated my computer in 3 years. and guys it will all be greatly appreciated any input you give. anyway ive got £550 to spend out of that im buying the E6850 and a 8800 GTS. so if u guys could use the rest of the money i think there will be around £150 - 170 change to select a motherboard, memory and a cooler would be much appreciated.
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
£69.99 (£82.24)
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit (BL2KIT12864AA663)
£54.99 (£64.61)
Tuniq Tower 120 Blue LED CPU Cooler (Socket 478/754/939/940/AM2/LGA775)
£26.99 (£31.71)
Total : £152.97 (£178.56 incl VAT)
Check with others regarding this spec, but I think is probably about the best you can get for the money - I take it you plan to overclock?
ps the Tuniq Tower comes without the chavtastic blue LED for the same price if you like...
Here is a system ive just been doing and woundered if u guys can see any problems ill have its all OC:uk stuff here it is
Motherboard
Gigabyte GA_P35_DS3P £99.86 inc VAT - does anyone know if this motherboard supports sata II
CPU
E6850 £199 - when the CPU comes out wll it drop in price by july 22nd?
Memory
GeIL 2GB (2x1GB) PC8500C5 1066MHz Black Dragon DDR2 Dual Channel Kit
£99.86 inc VAT
Hard Drive
Hitachi Deskstar T7K500 NCQ 320GB SATA-II 16MB Cache
£45.81 inc VAT
PSU
Hiper HPU-4M670 Type R 670W ATX2.2 PSU
£79.89 inc VAT
Cooling
Scythe Infinity Heatpipe CPU Cooler
£29.36 inc VAT
Why are you buying the most expensive CPU, two weeks before Intel price cuts? I would get a much cheaper CPU, see my review of a e2160 Vs a e6600 in this forum. I would get a e2160, and you'll have loads left for the rest of the components of your system.
Motherboard - I'd change it for the newer version, the P35C DS3R. Clocks even better, plus supports the upcoming penryn cpus.
Memory - I'd go for the OCuk PC8500 - cheaper and is still very fast at stock.
Hard Drive - I like Hitachi drives, but most people here will tell you Samsung and Seagate are faster.
PSU - Seasonic, Corsair, Enermax are the brands that you want to choose from. Hypers have been known to break and take many components with them when they do.
Cooler - Good choice.
ok thanks guy ill get back to you on the a new system right away with the imput u just given guys and monkey im sticking with the GPU ive got now and saving up more money after ive built the new system by then prices may have dropped for what i want.
Oh and for melbourne im not buying the CPU now im definatly waiting for the intel price cuts
OK guys heres my new system hope its to a decent standard and will all work
Motherboard
Gigabyte GA_P35C_DS3R (Socket 775) PCI-Express DDR2 & DDR3 Motherboard
£96.34 inc VAT
CPU
E6850 £199
Memory
OcUK 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz Dual Channel Kit
£70.49 inc VAT
Hard Drive
£45.81 inc VAT
PSU
Enermax Liberty 620W ELT620AWT ATX2.2 Modular
£99.86 inc VAT
Cooling
£29.36 inc VAT
If spending ~£200 on a CPU that you want to last for a couple of years you really should take a look at the Q6600. It'll be about £180 in 12 days time.
you know what i was originally going for the Q6600 but after reading a post on here Q6600 or E6850 i swapped but if you guys ensist and i trust your judgement i'll change it back so would that motherboard support the Q6600
