New System
14 May 2008
Ok was thinking about this new spec that will also have watercooling, anything i should change?
I would try and search around for the old V2000 series cases. The new one unfortunately aren't as good as the old ones, as they aren't big enough to fit two radiators in the bottom compartment, making it a pointless purchase if you plan to expand your loops in the future. Apart from that, it looks pretty good, and I don't see any reason to change anything there.
