New System
9 Jan 2009
This is a new system i maybe having built only querie on it is whether to have 6gb or 3gb and go for Vista 64bit as i have ultimate 32bit and 64 bit already to choose from am on 32 bit vista now
And also have the ati 4850 and crossfire it as already have one anyway here to add to the system so dont seem worth upgradeing to anything like a 4870
CAS: CoolerMaster Cosmos S Gaming Tower Case w/ Side-Panel Window
CS_FAN: Maximum Case Cooling Fans for your selected case, and match the colour of the fans already in the case
CPU: (Quad-Core)Intel® Core™ i7 920 @ 2.66GHz 8 MB cache LGA1366
CD: SONY DUAL FORMAT 20X DVD±R/±RW + CD-R/RW DRIVE DUAL LAYER
Advanced WaterCooling Kit (Including Radiator, Pumping, Reservoir, CPU Block, Tubing, and Coolant)
HDD: Single Hard Drive (500GB SATA-II 3.0Gb/s 16MB Cache 7200RPM HDD
MOTHERBOARD: Asus P6T Deluxe Intel X58 Chipset SLI/CrossFireX Mainboard SAS Triple-Channel DDR3/1600 SATA RAID w/ eSATA,Dual GbLAN,USB2.0,IEEE1394a,&7.1Audio
MEMORY: (Req.DDR3 MainBoard)(3x1GB) PC10666 DDR3/1333mhz Triple Channel Memory (G.SKILL PI Series w/Heat Spreader
NETWORK: ONBOARD 10/100 NETWORK CARD
POWERSUPPLY:(Tagan 800W TG800-BZ PipeRock Series Modular Power Supply)
PRO_WIRING: Professional Wiring for All WIRINGs Inside The System Chasis with High Performance Thermal Compound on CPU
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
VIDEO: ATI Radeon HD 4850 PCI-E x16 512MB Video Card
I will be replaceing the dvd drive with a blu ray drive from my old system which i bought and realised was bad idea resource wise and will also be putting an extra 1Tb drive in same speed and looking at 22" HD Monitors
I will also be changeing the onboard sound and putting in my xi fi 5.1 fatality pro card in as well
I been looking at the Asus VH226H 22" Widescreen True HD LCD Monitor - Black and the
Viewsonic VX2260wm 22" Widescreen True HD LCD Monitor - Glossy Black
But i also like style looks of samsungs so was also looking a t part HD 20" displays like The pebble and the aquas
Samsung SM2053BW Aqua 20" Widescreen LCD Monitor - Glossy Black
Samsung SM2032BW Pebble 20" Widescreen LCD Monitor - Glossy Black
Any opinions and advice would be good
since you have both versions already, I'd be putting on the 64bit myself and sticking in 6gb, you have crossfire and an i7 so that should be able to see you through if your not wanting to upgrade for a while
Personally, i wouldnt get anyone else to build it for you. It's pretty straight forward to put a pc together.
So i would buy all the components seperately, and put it together yourself.
Will also save you quite a big of money i imagine
Thats what i was thinking i have already submitted my order so gonna see if can ammend it on monday for the ram
Also first time have used liquid cooling thought it be new experience
They also do a overclocking service but not sure about that as i no how to overclock graphics and cpus never done memory or psus, was just wondering whats main components that need doing for vast performance and stability
I have looked into prices i reck if bought it all on credit card and built it myself would not save much in the time to pay it off prob about £300 and i intend to keep it good few years well most of it lol
