New System
9 Mar 2013
I'm building a new rig, that will be
INTEL CORE I7-4790K 4.00GHZ LGA1150 - BOX
CORSAIR CMD16GX3M2A2400C11 DOMINATOR PLATINUM 16GB (2X8GB) DDR3 2400MHZ DUAL CHANNEL KIT
SAMSUNG MZ-7TE250BW 840 EVO SERIES SSD 250GB 2.5'' SATA3
ASUS MAXIMUS VII FORMULA RETAIL WATCH DOGS BUNDLE
WESTERN DIGITAL WD20EZRX 2TB CAVIAR GREEN SATA3
EVGA SUPERNOVA 1000 G2 POWER SUPPLY 1000W
CORSAIR OBSIDIAN SERIES 900D BLACK
For fans ill be using CORSAIR AIR SERIES AF120 QUIET EDITION HIGH AIRFLOW 120MM FAN
So my watercooling shopping list so far is
1) XSPC RayStorm
2) Masterkleer tubing PVC Clear
3) Alphacool 16/10 compression fitting
4) Alphacool 16/10 compression fitting 90° revolvable
5) Alphacool 16/10 compression fitting 45° revolvable
6) Phobya 2 valve for draining the loop
7) Phobya Balancer 250 black matte <- I am not sure about that one...it might look small into 900D...maybe i shall go for the Balancer 450?
8) Koolance Laing D5 top
9) Alphacool VPP655PWM - Single Edition
10) Aquacomputer Shoggy Sandwich building kit for pump
11) Alphacool NexXxoS XT45 Full Copper 360mm <- will be placing that rad on top
12) Phobya G-Changer 480 V.2 - Full Copper <-That rad will go in the bottom place
What do you guys think?
