Hi i built a new rig yesterday:
SPEC:
i7-3770k
16gb 1600Mhz ddr3 geIL black dragon x2 8gb sticks
2tb hd
Asus P8Z77-V LX2 Intel Z77 mobo
OCZ ZT 550W '80 Plus Bronze' Modular Power Supply
Cooler Master Hyper 612S CPU Cooler.
Everything was fine once it was put together. i installed all the updates (windows 8 pro 64bit)
installed all the chipset drivers off the disc that came with the mobo!
Update the graphics and then did a stress test with primes95 and all was fine.
all the temps was fine between 20-23 degrees idle and 60 at load!
But then i started to install bf3 and it stopped half way through the install and i got this msg: your pc ran into a problem and needs to restart!
Then it rebooted!
I thought it might be a driver problem in windows 8 ( which i thought was strange as it's runnig fine on 2 other systems in my house)
so i re-installed windows 7 ultimate 64bit and instlled the chipset drivers again!
I started to install the updates and i got the BSOD again!
(also i tried to transfer a program that i had on an external hd that is rar'ed up, But every time i try to unrar it i get an error msg saying that the file structure is corrupt! But yet it's fine on other systems in my house)
I tried a doing the chkdsk and all came up fine, done memtest all came up fine
and now i'm just stuck and at a total loss and have no idea what the problem is! i do have the crash reports:
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Fri 18/01/2013 01:33:10 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011813-46925-01.dmp
uptime: 00:46:54
This was probably caused by the following module: ntfs.sys (Ntfs+0x213D8)
Bugcheck code: 0x24 (0x1904FB, 0xFFFFF88007B3E3B8, 0xFFFFF88007B3DC10, 0xFFFFF880012F7B76)
Error: NTFS_FILE_SYSTEM
file path: C:\Windows\system32\drivers\ntfs.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT File System Driver
Bug check description: This indicates a problem occurred in the NTFS file system.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
uptime: 00:46:54
On Fri 18/01/2013 00:42:43 GMT your computer crashed
crash dump file: C:\Windows\Minidump\011813-20810-01.dmp
uptime: 00:26:22
This was probably caused by the following module: ntoskrnl.exe (nt+0x71F00)
Bugcheck code: 0x50 (0xFFFFFA820D9714B0, 0x0, 0xFFFFF80002AAAA79, 0x5)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: C:\Windows\system32\ntoskrnl.exe
description: NT Kernel & System
Bug check description: This indicates that invalid system memory has been referenced.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
pls any help what so ever i would greatly appreciate it
SPEC:
i7-3770k
2tb hd
Then it rebooted!
Crash Dump Analysis
uptime: 00:46:54
uptime: 00:46:54
uptime: 00:26:22
