New to gaming PCs - need advice on pre-built system
25 Nov 2022
Whitchurch
Hi guys, I'm looking for a system to suit a teen into AAA and FPS games (currently uses a PS5) and wondering if the following seems like a reasonable set up. I've chosen the components based on researching threads on here and going to pretty much maximum budget. Any advice would be gratefully received.
OcUK Tech Labs Intel 12th Gen Midi Gaming PC Configurator
SKU FS-021-TL
  • 1x Lian Li LANCOOL 215 Mid-Tower aRGB Tempered Glass Black
  • 1x *Build* Intel Core i5 12400F up to 4.4GHz Turbo - Six Core, Twelve Thread Processor
  • 1x MSI MAG B660M Mortar WIFI DDR4 - Intel B660 DDR4 Micro ATX Motherboard
  • 1x Arctic Liquid Freezer II High Performance CPU Water Cooler - 240mm
  • 1x Corsair Vengeance LPX 32GB (2x16GB) DDR4 PC4-25600C18 3600MHz Dual Channel Kit (CMK32GX4M2D3600C18)
  • 1x Asus GeForce RTX 3060Ti Dual Mini V2 OC LHR 8GB GDDR6 PCI-Express Graphics Card
  • 1x WD Blue SN570 1TB SSD NVME M.2 2280 PCIe Gen3 Solid State Drive (WDS100T3B0C)
  • 1x Phanteks RGB LED Strip Starter Kit (PH-LEDKT_CMBO)
  • 1x ASUS USB-AC51 Dual-Band Wireless-AC600 Wi-Fi Adapter
  • 1x Seasonic Focus GX-750 750W 80+ Gold Modular Power Supply
  • 1x Microsoft Windows 11 Home 64-Bit DVD - OEM (KW9-00632)
Quantity: 1
£1,563.85
Save some cash by Dropping Windows, you can get a key for much, much less elsewhere. Could drop to 16GB of RAM as well and ask OCUK to improve the graphics card using those savings to the 3070 option.
You also don't need the Wi-Fi card, the motherboard has Wi-Fi built in.
You really have done your research, this is pretty much what would be recommended within your budget.
Win10 is free and downloadable from Microsoft website. You do not need Win11 with that cpu and it will work perfectly fine with Win10
Like mentioned above you do not need the wifi card.
Could save a few bob and go with this instead.
My basket at OcUK:
  • 1 x OcUK Tech Labs Intel 12th Gen Midi Gaming PC Configurator (SKU: FS-021-TL) = £1,311.88
    • Case: 1 x Lian Li LANCOOL 215 Mid-Tower aRGB Tempered Glass Black
    • Processor: 1 x *Build* Intel Core i5 12400F up to 4.4GHz Turbo - Six Core, Twelve Thread Processor
    • Motherboard: 1 x MSI Pro Z690-A WIFI DDR4 - Intel Z690 DDR4 ATX Motherboard
    • Cooler: 1 x Arctic Liquid Freezer II High Performance CPU Water Cooler - 240mm
    • Memory: 1 x Team Group Vulcan Z T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey
    • Graphics Card: 1 x Asrock RX Radeon 6700 XT Challenger D 12GB GDDR6 PCI-Express Graphics Card
    • Primary Solid State Drive M.2: 1 x WD Blue SN570 250GB SSD NVME M.2 2280 PCIe Gen3 Solid State Drive (WDS250G3B0C)
    • Lighting: 1 x Phanteks RGB LED Strip Starter Kit (PH-LEDKT_CMBO)
    • Power Supply: 1 x Seasonic Focus GX-750 750W 80+ Gold Modular Power Supply
