- 13 Aug 2009
I have a i5 3690K, on a Asus hero vii board.
Cooler is Corsair h110 cooler, with SP140 replacement fans.
I installed all the asus apps/bios from the website, current using 1 stick of ram @ 1600 mhz
I tried the auto OC at 4.2 was fine, then 4.4, now 4.6 Ghz @ 1.28v and it seems stable.
Running prime small FFT's and no core is over 55C, just seems like its misreporting.
Using speedfan and the asus utility to monitor temps, core temp seems to crash out some.
30 mins and no errors on prime ?
Anything i should look out for ?, whats volts is max i should use.
Just my OC seems kinda easy i presume 4.6ghz was not the norm.
I even used the default paste on the h110, though o do have some MX4 and AS5 laying arround .
