I've got my AMD Opteron 165 running at 2760Mhz, it was running very stable at 2715Mhz, i wanted to increase the RAM speed back up closer to 200Mhz as it was at 193Mhz, i tried increasing the core speed to 305Mhz and it failed to post, so I increased it with the voltage to 1.4185 and it seems to be running well.
I'm trying to get my RAM back up to speed, currently its at 197.2Mhz, i know i can run it well at 208Mhz but I can't work out what settings i need my FSB, memory divider and core speed to be to get it all to run well.
I can't increase my CPU divider any higher than 9x.
Any suggestions greatly appreciated.
My full PC spec is:-
1 x AMD Opteron 165 Socket 939 1.8GHz Dual Core 2x1MB @ 2712Mhz
2 x 1GB Corsair XMS 3200 CL2
2 x Gainward 7900GT in SLI (Overclocked to 500Mhz core, 700Mhz Memory)
2 x Seagate ST3250823AS 250GB 7200RPM SATA/150 8MB Cache, RAID Stripe
1 x Enermax Liberty 620W Modular ATX2.2 PSU
1 x Asus A8N-SLI Deluxe S939 NF4 SLI ATX
1 x Zalman (CNPS7700-ALCU ) 120mm Super Flower Cooler (Al/Cu)
