- 13 May 2011
- Essex
Just bought a replacement psu as mine is playing up full thread here http://forums.overclockers.co.uk/showthread.php?t=18345688.
I've decided it's about time I tried my hand at basic overclocking, so bought this Cooler Master Hyper 212 Evo CPU Cooler as well with some Artic Cooling MX-4 Trim.
I would like to ensure my Cooler Master HAF 912 Plus Case case fans are set up correctly before I attempt to replace the above items.
Case came with 1 x 200mm fan at the front sucking air in & 1 x 120mm fan at the rear sucking air out.
I have added 1 x 120mm fan to the side sucking air in & 2 x 120mm fans to the top sucking air out.
The speeds as shown in the Asrock Extreme Tuning Utility are;
Front 200mm = 690
Rear 120mm = does not show (Think this is as it is connected to a molex connector)
Side 120mm = 1275
Top 120mm = Both around 1300
CPU idle in Core Temp says 34/34/39/31 (I understand this may/will change once the new cooler is installed)
Questions
What can I do to get the Rear 120mm fan speed to show up so I can monitor it.
Are the fans installed correct for optimal cooling/airflow?
Do you think the fan speeds are adequate?
Front 200mm = 690
Side 120mm = 1275
Questions
