Hello, I have recently bought the Zalman VF700-CU VGA cooler for my XFX 6600GT and although I can't fit all the mini RAM heatsinks on due to the XFX's crazy diagonal design I'm very happy with it's results. This has enabled me to over clock it only by a smallish amount but enough to guarantee stable FPS on my current TES IV:Oblivion settings
So what I want now is to overclock my CPU (AMD Athlon 64 3200+ ClawHammer) but I think I will need to buy a new CPU cooler and a 120mm Fan for the rear of the case (as I only have 1 80mm fan at the front of the case at the mo).
My question is: Is this a good choice - the Scythe Ninja Plus Heatpipe CPU Cooler? Is it compatible with my CPU, should be as it's a socket 754.
Secondly, as it (the Scythe) comes supplied with a 120mm fan can I use that as my rear case fan rather than putting it on the Scythe Ninfa Plus as I don't think my CPU will require it OR should I buy a different 120mm rear case fan and if so which one?
Thanks for reading and any responses.
